sc2018's avatar
sc2018
Can I upgrade SRX5308 firmware from 3.06 to 4.21
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi sc2018,
    Welcome to the community! :)
    Yes, you can.  Be reminded that the configuration file saved when using firmware v3.06 will not be applicable when you want to restore it after upgrading the firmware to v4.21 or higher.  You will need to reconfigure the settings from scratch.
    It would be best that you to upgrade the firmware to the latest version which is 4.3.5-3.  You can download it here.  Be sure to perform a factory reset after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version.
    DaneA
    NETGEAR Community Team
    • sc2018's avatar
      sc2018
      What I mean is I need to get the business back up, so i have a goodd cfg on the 3.06 I just want to apply the latest firmware with my current settings. I can reset at annother date and reconfigure then. Make sense?
      • DaneA's avatar
        DaneA
        sc2018,
        Upgrading the firmware from v3.x.x (like v3.06) to v4.x.x (like v4.21 or v4.3.5-3) requires a factory reset.
        I suggest you to upgrade the firmware during non-production hours (like during weekends or holidays) so that you will be able to factory reset the SRX5308 right after upgrading the firmware then reconfigure the settings from scratch.
        DaneA
ProSupport for Business
