techguru
Jan 11, 2017Aspirant
Can't Find - VPN Client license key lost for SRX5308
Purchased the firewall in November 2015 and just now need to use the VPN features. Unfortunately, I cannot locate the original five VPN Client software. Can you provide me the license key s...
- Jan 11, 2017
Hi techguru,
You're welcome! I have sent the license key thru PM.
Thanks,
techguru
Thanks for the quick reply.
Sent a PM
JohnRo
Jan 11, 2017NETGEAR Employee Retired
Hi techguru,
You can download the latest VPN Lite software version here. Let me know if you need anything else. :)
Thanks,
- techguruJan 16, 2017Aspirant
When trying the serial provided, the program says it is still in use when we have not installed any!!!
Please help. Sent you a PM on the same.
Thanks
- JohnRoJan 16, 2017NETGEAR Employee Retired
Hi techguru,
I have responded thru PM as well. I have re-sent the key, I need to know what error message you are getting. It will help if you can provide a screenshot. Our system says that the license keys are not in use.
Thanks,
- JohnRoJan 19, 2017NETGEAR Employee Retired
Hi techguru,
I'd like to follow up if you were able to use the license key I have provided. Please let us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
