Sil68
Nov 09, 2015Aspirant
Connection drops/connection timeouts with Netgear FVS381N
Hi, Just recently I've switch ISP (to a cable provider), and in doing so my infrastructure changed accordingly. Now I've got a cable modem (technicolor TC7200U) linking my LAN to the big wide wor...
Sil68
Nov 11, 2015Aspirant
Hi,
Thanks!
Actually the two-layer defense is there on purpose, so any intruder managing to get past the technicolor barrier, is still facing another one.
Also I've got a guest wi-fi between these two routers.
As mentioned with my old FVS318 v1 these issue were not observable, only the achievable throughput was poor.
So I really would like to find a solution to get the FVS318N working properly as a drop-in replacement for my old FVS318 v1.
--Sil68
Thanks!
--Sil68
- DaneANov 11, 2015NETGEAR Employee Retired
Hi Sil68,
For me, the recommended network setup is that the Public WAN IP Address should be registered to the firewall which is the FVS318N. However, you may want to try to perform a factory reset on the FVS318N then reconfigure it from scratch and observe if same problem occurs on your current network setup.
DaneA
NETGEAR Community Team
- Sil68Nov 12, 2015Aspirant
Hi DaneA,
I'm afraid, this was to no avail; after resetting and re-configuring, the symptoms are still observable.
--Sil68
- DaneANov 15, 2015NETGEAR Employee Retired
Hi Sil68,
Have you tried to open ports in the Technicolor TC7200U such as ports 443 and 80 and point it to the IP address of the FVS318N?
If ever opening ports will still not help then you may want to consider the recommended network setup that I have mentioned previously on one of my responses to you wherein the Public WAN IP Address should be registered to the firewall which is the FVS318N making it the main router in order to isolate the problem.
DaneA
