Retired_Member
May 22, 2011DHCP Relay over VPN
Hi Guys, I have a problem with setting up DHCP relay mode over my VPN. The VPN works ok and I can access the remote router, printers, etc via their internal IP address (192.168.0.xxx) no problem. My...
- Jun 03, 2011Just be aware that its not really a good idea to run DHCP over a VPN as if for whatever reason the VPN goes down, the computers at the remote site won't be able to get an IP address & the whole network there could go into meltdown... Personally I use DHCP on the site with the server and remote sites I use static. I could probably use a local DHCP server at each site, but for the number of PCs involved, using statics was easier.
adit
May 27, 2011Mentor
Makes no difference. Just program the remote site router DHCP to use the SBS as the DNS server. Everything will work fine.
