DCrusher
Jul 11, 2017Aspirant
Drops internet connections FVS318N with the newest firmware
Well after updating to the newest firmware. This has turned in to a nightmare. I can't remember how long I've had it but I've always had to reboot it maybe once or twice a week for losing the WIFI now after the update firmware now it losing the internet connection. I have no problem rebooting it but it went from once or twice a week to 3 or 4 times a day. So I down graded to much earlier version firmware still does the something so basically this thing is junk now. I don't mind rebooting every now and then but NOT every couple of hours to hell with that so I broke out my old D-Link 8 port WIFI been running with out a glitch for 2 days its a 10/100 so it's a little slower but right now I'm willing to sacrifice speed for reliability im tired of getting up and go in to other room and reboot just so I can finish sending email or receiving it give me a break. This can't be this difficult to make it just work. I have a simple configuration I use it for all the computers and for mobile devices I never have more than 2 mobile devices on it at once and maybe 2 computers on at once so why is this keep dropping the internet its behind a AT&T uverse residential gateway and the WIFI or internet never goes down I just want the netgear to work like the AT&T gateway works flawless... any ideas I'll be more than happy to try.
- JohnC_VNETGEAR Employee Retired
Hi DCrusher,
Have you tried resetting it to factory default and try to connect if it will work on default settings? If yes then this might probably a hardware issue already. Please create a chat / case online on NETGEAR support and if ever the device is still under warranty, an online replacement will be provided.
- DCrusherAspirant
Yes I have update the firmware and reset it. Now I just have to renter thing and right now I'm going to run it as a TESTING next to the D-Link. As for warranty you don't have to worry about that it's 2 or 3 years old. I just very happy you helped because I'll try anything to get my netgear back up my D-Link is great but speed is lacking. Thank You.
I just want to have a follow up on this thread that you created. If you were able to reset it to factory default. Please let us know the update of your issue.
