troothteller
Feb 17, 2018Aspirant
FVS114 New On Network, No Telephone
Boy, it is difficult to use this forum. I chose the closest model to what I have just to get this going. I have the FVS114 which I may have purchased as far back as 2006, but never installed. Two wee...
troothteller
Feb 19, 2018Aspirant
DaneA, thank you for your reply, an unexpected surprise. Until now I did not know that I was adding another router to the network, although the ProSafe is probably not wireless. I will implement the steps later. However, I will upload a more accurate diagram of my network so you can see how I hooked up things. Thanks again. it is an Excel document; but you can ignore the second page
troothteller
DaneA, I connected the PC (laptop) directly to the firewall. It did not directly connect but formed under Network Connections a Network 2. Since I did not expect that, I put the wiring back to where it was. I guess that the firewall is on another address while the router is on a static address. Your link led me to an article "How to set the cable modem/router to be on modem only;" but my settings do not look like the ones in the article.
