kamik1979
Mar 05, 2022Follower
FVS318G 3.1.1-18 login loop
After upgrading my FVS318G to version 3.1.1-18 and after logging into router, clicking on any link on the router page redirects me to "session expired" screen and prompts to login again. After another login it gives me information that "'admin' already logged in from [IP]" and gives me two options: "continue" to close the previous session and "cancel". Clicking continue brings me back to login screen with information "Operation succesfully completed". Any try to login again will result in the same, and I'm stuck in a loop. Resetting to factory defaults with "Factory defaults" button does nothing, same with the 30-30-30 method (after doing 30-30-30 DMZ and Test LEDs are blinking and there is no connectivity). My router is currently bricked. Does anyone know solution to this problem?
1 Reply
- DaneANETGEAR Employee Retired
Welcome to the community! :)
What is the behavior of the LED lights of the FVS318G?
Since the FVS318G is an old NETGEAR device and it is already End-of-Life, kindly try to use an old browser like Internet Explorer 7 or 8 then check if you will be able to access the web-GUI.
DaneA
NETGEAR Community Team
