Peter_A
Dec 17, 2015Aspirant
FVS336GV2 19" Rack Mount Kit - SKU or P/N:
Hi all, As the subject suggest I'm chasing the purchase of a rack mount kit for our FVS336GV2 and could do with the Netgear part number to order if someone can list it please? The manual show...
- Dec 21, 2015
Hi Peter_A,
Welcome to the community.
I regret to inform you that it seems there is a mistake in the manual of the FVS336Gv2 for it is not intended for rackmount design.
DaneA
NETGEAR Community Team
Peter_A
Dec 26, 2015Aspirant
Hi Dane,
Thanks for the reply over the festive season.
You are correct in that there must be an error in the manual.
On further inspection of the physical unit it does not have and mounting holes in the case to support any kind of rack mount bracket attachment.
I will have to install a small slotted shelf in the rack that is just big enough to sit the unit on.
Peter.
