amemo06
Jun 14, 2016Aspirant
FVS336Gv2 Access configuration of ADSL modems in bridge
Hi, Since long time I have 2 ADSL modems connected to my FVS336Gv2 routeur. Both modems are in Bridge mode. So that the PPOE identification is done by the router. All works like a charm. Still I h...
JohnRo
Jun 14, 2016NETGEAR Employee Retired
Hello amemo06,
When a modem is in bridge mode it usually disables access to the user-interface or it uses an administrator login (which is usually accessed by their support team). If the WAN1 and WAN2 port give you an IP address it means that there is an active modem on the port. The routers do not display any connectivity status of the modem. If you want access to web-UI of the modem, you'll have to take it off bridge mode or configure it as router+bridge (some of our older has that setting).
Thanks,
