amemo06
Jun 14, 2016Aspirant
FVS336Gv2 Access configuration of ADSL modems in bridge
Hi, Since long time I have 2 ADSL modems connected to my FVS336Gv2 routeur. Both modems are in Bridge mode. So that the PPOE identification is done by the router. All works like a charm. Still I h...
JohnRo
Jun 17, 2016NETGEAR Employee Retired
Hi amemo06,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
- amemo06Jun 18, 2016Aspirant
Hi JohnRo, thanks for the replies.
Well it did not solved the issue but at least confirmed that there is no solution when modems are configured in bridge mode.I will try to configure them in non-bridge mode (PPOE) and try to setup my router to access them.
- JohnRoJun 20, 2016NETGEAR Employee Retired
Hello amemo06,
Yes, unfortunately, most modems loses their UI when configured in bridge mode. Keep us posted.
Thanks,
