phipo_neo
Nov 02, 2016Aspirant
FVS338 firmware issue
hi, I've do many hard reset and i lost the firmware, the led test is always turn on. i not have a web access managing ! when i connect directly to the computer by eternet cable the IP adress of th...
JohnRo
Nov 03, 2016NETGEAR Employee Retired
Hello phipo_neo,
Welcome to the community!
It appears bricked, try resetting the router/firewall using the sequence below:
- Push and hold the reset button for 30 seconds.
- Turn off the unit, continue to hold the reset button for another 30 seconds.
- Turn on the unit, and hold the reset button for 30 seconds more.
- Release the reset button and let the unit boot normally.
See if this will make any difference.
Thanks,
phipo_neo
Nov 03, 2016Aspirant
hi,
i've found a program for upload the firmware : cutecom
but after spook with a friend this last tell me tha there are 2 memory flash
Now how i can to swap the firmware into the primary flash
Best regards
Philippe
- phipo_neoNov 03, 2016Aspirant
my system tell me there no IP adress assigned
