sat444's avatar
sat444
Fvx538 random reboots
Hello,
I have an FVX538 firewall that has been rebooting randomly over the past month. It did it again this morning and I received the following netgear monitoring email ( see below). I am running firmware version 3.0.7-24.
Another question i have is why does my date say Dec 31, 1969 ?
I look at the gui and my date is correct. I seen a few other forms on this site and the logs had similar dates. Is the date just some Netgear default ?
1969 Dec 31 19:00:23 [FVX538] [ntpdate] ntpd: Not a lan ntp server
1969 Dec 31 19:00:45 [FVX538] [root] [SYSTEM START-UP] System Rebooted
1969 Dec 31 19:00:51 [FVX538] [wand] [FW] Firewall Restarted
1969 Dec 31 19:00:55 [FVX538] [kernel] WAN2LAN[ACCEPT] IN=WAN OUT=LAN SRC=65.190.183.17 DST=192.168.10.200 PROTO=TCP SPT=1108 DPT=1723
1969 Dec 31 19:00:56 [FVX538] [wand] [IPSEC] IPSEC Restarted
1969 Dec 31 19:01:02 [FVX538] [wand] [FW] Firewall Restarted
1969 Dec 31 19:01:06 [FVX538] [wand] [IPSEC] IPSEC Restarted
1969 Dec 31 19:01:24 [FVX538] [wand] [FW] Firewall Restarted
1969 Dec 31 19:01:26 [FVX538] [kernel] WAN2LAN[ACCEPT] IN=WAN OUT=LAN SRC=173.95.170.60 DST=192.168.10.200 PROTO=TCP SPT=59533 DPT=1723
1969 Dec 31 19:01:26 [FVX538] [kernel] WAN2LAN[ACCEPT] IN=WAN OUT=LAN SRC=76.3.113.248 DST=192.168.10.200 PROTO=TCP SPT=15256 DPT=1723
1969 Dec 31 19:01:41 [FVX538] [wand] [FW] Firewall Restarted
1969 Dec 31 19:01:46 [FVX538] [wand] [IPSEC] IPSEC Restarted
1969 Dec 31 19:02:07 [FVX538] [wand] [LBFO] WAN 2 Status : WAN cable Disconnected _
1969 Dec 31 19:02:07 [FVX538] [wand] [LBFO] WAN-2 Test Failed 1 of 3 times_
1969 Dec 31 19:02:08 [FVX538] [ntpdate] ntpd: Installing firewall rules
1969 Dec 31 19:02:09 [FVX538] [ntpdate] Looking Up time-a.netgear.com
1969 Dec 31 19:02:09 [FVX538] [ntpdate] Requesting time from time-a.netgear.com
1969 Dec 31 19:02:09 [FVX538] [ntpdate] ntpd: Executing ntpdate -s 209.249.181.22
1969 Dec 31 19:02:09 [FVX538] [ntpdate] ntpdCmdExec: exec'ing -> ntpdate -s 209.249.181.22_
  • Router did not sync with NTP server. I wold try using different NTP server .
  • I do see the ntp server fail but I don't feel that would make the server reboot.
    If you were saying the NTPserver is the reason for the date / time problem in the log - wouldnt this also effect the gui ? The time in the gui is correct.
  • 1969 is the default date in the firmware. This is the date/time before the router syncs with a NTP. Use these NTPs, they are the most reliable: us.pool.ntp.org 0.pool.ntp.org 1.pool.ntp.org 2.pool.ntp.org 3.pool.ntp.org The NTP has nothing to do with why the router is rebooting, not sure why it was even mentioned. I'm only aware of 3 things that can cause it to reboot: 1. Power issue 2. Overloading the router 3. Hardware failure
ProSupport for Business
