Stuartsjg
Aug 16, 2015Aspirant
FVX538v2 dropped/unstable PPPoE connection
Hello, I bought a FVX538v2 from eBay as im a great fan of netgear products. This is to replace my ISP supplied router which lacks any VPN functionality. My preference is often for slighly old...
JohnRo
Aug 17, 2015NETGEAR Employee Retired
Hello Stuartsjg,
Welcome to the community!
It appears that you have an intermittent WAN connection with your router. I have some questions to help us isolate the issue, I have listed them below:
1. When you lose internet, does the LED on the WAN port still light up?
2. Can you still access the UI interface when you lose the internet?
3. Do you still get a Public/WAN IP?
This product has been EOL (end of life) and was replaced with the SRX5308, unfoturnately there are no newer firmware versions that we can test.
I'll look forward to your reply.
Thanks,
