Kerebel
Jul 03, 2017Aspirant
Impossible upgrade
Our FVS 336Gv2 routeur is running an old firmawre version : 3.0.9-02
After uploading the latest version, (4.4.3-6), unzipping the file, the Upgrade button processes (apparently) the .img file and reboots.
But it remains in the old firmware version...
OK, furthermore, the factory reste will change its IP to 192.168.1.1 as this sub network is 192.168.2.x ; I'll do it next time I go in this lovely region of Pau (France) !
Thanks !
- DaneANETGEAR Employee Retired
Hi Kerebel,
Welcome to the community! :)
Since firmware v3.0.9-02 is an old firmware version, I suggest you to upgrade the firmware in a ladderized manner. First, upgrade the firmware from v3.0.9-02 to v3.1.1-08. Then, upgrade the firmware from v3.1.1-08 to v4.3.1-18 and so on until you get to upgrade to the latest firmware v4.4.3-6. Be reminded to perform a factory reset on the FVS336Gv2 after upgrading the firmware to the latest version then reconfigure it from scratch in order to have a clean start using the latest firmware.
You may download the firmware versions for the FVS336Gv2 here.
DaneA
NETGEAR Community Team
- KerebelAspirant
Thanks for your prompt answer.
As this routeur is located in a remote site, I suppose it's recommanded to upgrade it on site and not through our VPN from the head quarters ?
