mpratt
May 05, 2019Aspirant
incoming Access thru firewall
Hello, I have a prosafe gigabit 8 port firewall FVS318G, setup and working well with default settings. In my home network I have setup a PC running freenas. I have also setup a web (HTTP) address to...
mpratt
May 12, 2019Aspirant
Thank you for the response. I am a novice in setting up this router and need a little more help. I reviewed the parts of the manual and understand most, not all of the settings I need to apply.
My router address is 192.168.1.1 and the NAS server is 192.168.1.137.
My LAN WAN inbound services settings are:
Service: HTTP
Action: ALLOW always
Send to LAN Server: Single Address
Start: 192.168.1.137
WAN Destination IP Address: Broadband
WAN Users: Any
Log: Never
Bandwidth Profile: NONE
When the rule is disabled, the web address brings up the router sign in screen.
When the rule is active, the connection times out.
Thanks again in advance.
DaneA
May 13, 2019NETGEAR Employee Retired
Hi mpratt,
Since you have already allowed HTTP for inbound service, kindly verify if its really open by using an online port scanner like here.
Also, check if HTTP access is already configured to be allowed on the FreeNAS.
Let us know the result.
DaneA
NETGEAR Community Team
- mprattJun 23, 2019Aspirant
Results:
Checked port 80 on Host/IP masonportal.com...
The checked port (80, service http) is online/reachable!
Completed portscan in 0.2988 seconds.Also, I am not sure where the setting to allow the Freenas server is on this unit.
Thanks.
- DaneAJun 24, 2019NETGEAR Employee Retired
I searched online and found out that it seems that HTTP is not the port that you need to open on the FVS318G to access your FreeNAS outside your network. Kindly access the following links below then read:
https://www.makeuseof.com/tag/set-freenas-server-access-files/
Hope it helps. :)
DaneA
