Marksmt's avatar
Marksmt
Migrating from UTM-25 to FVS336G
Hi
I will soon be retiring an elderly UTM-25 which has several years of accumulated tweaks and changes installed on it to a brand new FVS336Gv3. This includes a couple of VPN links (one to an overseas office) and various port forwarding rules etc.  When I inhertited the UTM-25 we never used any of the UTM features. It was used purely as a VPN and DMZ firewall (DMZ for our local WLAN). A remote office will have another Netgear devices at the other end of the VPN link. Not sure what model this is at present.
Is there some script or utility which can assist in transferring the settings from one device or do I have to hunt around all of the pages of the old unit and laboriously transfer each setting and keep testing until it works. (Not to mention recreating the certs and downtime in our remote office) ?
I would have thought it possible for the developers to offer some rudimentary script to transfer perhaps the most basic settings across such as the port forwarding rules, VLAN and DMZ config?
Thanks
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello Marksmt,
    Welcome to the community!
    I haven't really seen one of these scripts to transfer, especially from UTM series. You know it is a big leap transferring config from a UTM to a regular VPN firewall since there are a ton of features that will be lost upon the transfer. I'll inquire this to our engineers and see if there is any.
    Thanks,
    • Marksmt's avatar
      Marksmt
      Thanks!
      We have never used the UTM device functionally as anything over an above the features offered by the new unit. If there is a script which can migrate the bulk of the settings, leaving a few odds and ends to be tidied up that would be wonderful.  Migrating VPN config and certs would be really useful.
      I was looking at a hex dump of the backup and thinking that even a full/detailed config report of every setting might even help. I can't say I've noticed the option to dump the config in human-readable format on the UTM. Failing that, I guess it will be a few hours hunting through all of the screens, jotting down settings, checking then reprogramming everything into the new FWR.
      Given the end of life this year for the UTM series I guess there might be a number of hard-pressed IT guys in the same boat :)
      Regards
      Mark
      • JohnRo's avatar
        JohnRo
        Hi Marksmt,
        I just got an information from our engineering. Unfortunately, we do not have any scripts or utilities to transfer configurations from UTMs to FVS series routers. As I have mentioned in my last post, they are two different router platforms since the UTM has a lot more features than the FVS series and there are also some features on the FVS that are not available on the UTM. The best thing to do is just to get a screenshot of the pages where there is configuration.
        Thanks,
ProSupport for Business
