Roccade
Feb 03, 2024Aspirant
need some help with acces my RAX120 router with VPN
I want to acces my router from outside with a VPN Tried a couple of things last days with nothing seems to work Can anyone help me to set a VPN connection to acces my local network from outside?
Roccade
Mar 10, 2024Aspirant
can you explain this a little bit more?
Maybe i reading i wrong, but is this a solution for my problem?
schumaku
Mar 18, 2024Guru - Experienced User
Just tried to understand what for intentions and plans for a VPN are :
- what kind of VPN you have in mind,
- and your RAX120 does have public routeable IPv4 address assigned, to be reachable from the Internet
Users come often here with interesting ideas on what a VPN would be.
The fine Nighthawk AX12 12-Stream AX6000 WiFi Router Model RAX120 User Manual does have a comprehensive chapter, 10 Use OpenVPN to Access Your Network, with an intro section on VPN Connections your consumer router.
Difficult to provide a solution without an obvious (or less obvious) problem.
Start asking Google "What's my IP address", and compare if the result does match to the IP address you see on your RAX120 WAN/Internet connection details.
