iToon
Aug 19, 2013Novice
Netgear FVS336G WAN 2 Timeouts
Hi, I have a Netgear FVS336G with two WAN connections, WAN 1 is a EFM Circuit and WAN 2 is an ADSL Circuit, WAN 1 is connected to a Draytek Vigor 2930 from LAN on the Draytek to WAN 1 on the Netge...
jmizoguchi
Aug 19, 2013Virtuoso
In Fail over after see the drops and uses the secondary WAN it should work fine. If the AD is pointed to gateway of the router like you said it should work
btw, useless to mask private ip
192.168.**.***
