iToon
Aug 19, 2013Novice
Netgear FVS336G WAN 2 Timeouts
Hi, I have a Netgear FVS336G with two WAN connections, WAN 1 is a EFM Circuit and WAN 2 is an ADSL Circuit, WAN 1 is connected to a Draytek Vigor 2930 from LAN on the Draytek to WAN 1 on the Netge...
iToon
Aug 20, 2013Novice
DNS on the server points to itself locally then our second domain controller as the secondary with 8.8.8.8 & 8.8.4.4 and 85.189.102.5 & 85.189.39.5 as forwarders and the settings use "Root Hints" if forwarders aren't available" all computers on the network point to the Internal DNS Server.
Thank You
Thank You
