wmbexpert
Jun 13, 2020Aspirant
Netgear VPN reset license reset
I have a 5 user license pack (ProSafe VPN Client Lite for 5 users) installed on some laptops which have crashed which I have now replaced with new laptops. Unfortunately I am unable to uninstall the ...
- Jun 14, 2020
I got your private message hours ago and sent a request to reset your 5-user VPN license key. I just got an update that your 5-user VPN license key has been reset.
You may re-register the 5-user VPN license key to your new laptops.
Since your concern has been addressed / resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Jun 14, 2020NETGEAR Employee Retired
Welcome to the community! :)
The 5-user VPN license key needs to be reset so that you can use it to the new laptops. Kindly send me the following below via private message:
a. the 5-user VPN license key that needs to be reset
b. e-mail address/es that was used when you have registered the VPN license key
DaneA
- DaneAJun 14, 2020NETGEAR Employee Retired
DaneA
- wmbexpertJun 14, 2020Aspirant
Thank you very much
