oifadultcare
Apr 27, 2017Aspirant
New Installation
Hi, we are a small housing facility in St Cloud, MN. I purchased a firewall to add to our business (6 computers and a printer). We currently have a Century Link modem with static ips. Everything was working fine before I connected the Netgear router. In order to just get the network back up, I connected the FVS318G to the Century Link modem and am currently using the ip's provided with FVS318G instead of the static ips. I would like to continue using the static ip's (if in fact they will add another layer of security for our network). The reason for adding the Netgear firewall is to stop the hacking of our printer, which has occurred several times. Also, I am having problems setting up the network printer on a computer using wireless. The computer does not see the printer on the network. Another issue is using remote desktop. I do a lot of remote loging in from home and i have no ideal of how to get this working with the FVS318G firewall. I am a computer person but not a network person and I do not have a lot of time to try and figure this out. I really could use some help or information on vendors in my area who do on-site network support.
Thanks
Thanks for the update. I'm glad that you were able to set up the Nighthawk router. :)
Our Community Team for the Nighthawk Routers will be the one to check on your post and respond to it.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi oifadultcare,
Welcome to the community! :)
About having problems accessing the network printer on a computer via wireless connection, kindly answer the questions below:
a. To isolate the problem, have you tried to connect both network printer and computer directly to the FVS318G then check if you will be able to gain access to the network printer on the computer?
b. Since the computer is wirelessly connected to your existing network, is it within the same IP range as the local are network of the FVS318G? Kindly check the computer's wireless IP address if its the same IP range with the network printer.
c. Have you tried using other computer to isolate the problem in accessing the network printer wirelessly?
d. Since you have a wireless network, are you using a NETGEAR access point? If yes, what is the model number of it?
About remote desktop from outside the network, the Remote Desktop port which is port 3389 should be open pointing to the LAN IP Address of the PC you want to access from outside your network. Be sure that the FVS318G is set as the main router wherein the WAN IP Address should be a Public IP address registered on the FVS318G. Kindly follow the steps below:
1. On the web-GUI of the FVS318G, go to Security > Services.
2. On the section of Add Custom Service, enter the following:
Type: TCP
Start Port: 3389
Finish Port: 3389
3. Click Add.
4. Still on the web-GUI of the FVS318G, go to Security > Firewall > LAN WAN Rules.
5. On the section of Inbound Services, click Add
6. On the Add LAN WAN Inbound Service, indicate the following:
Service: select the name Remote Desktop that you've created in Services
Action: Allow Always
Send to LAN Server: select Single Address or Address range to apply the rule to a single device or to a range of devices respectively.
Start / Finish: fill-up these fields with the appropriate LAN IP address/es that you wish to remote access.
7. Click Apply.
To double-check if the Remote Desktop port 3389 is opened, access this online port scanner here and do the following:
1. On the "Enter IP or host to scan" field, this is autmatically filled-up with the WAN IP Address. Take note that the WAN IP Address should be a Public IP Address and it should be registered to the FVS318G.
2. On the "Enter Port to scan" field, type 3389.
3. Check the box that says "By selecting this option you confirm that you agree to the "Terms of use" below"
4. Click on Scan Port. If it shows "online/reachable!" then it means that port 3389 is open and you should be able to do remote desktop from outside your network.
DaneA
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
- oifadultcareAspirant
Hi, no I have not had a chance to try your suggestions. As I stated in my initial post. I am very busy and really do not have any networking experience only computer experience (software and hardware). I decided to roll everything back to the Century Link modem and just continue with the original settings until I can get someone with networking experience to come on site to help with setting up the Netgear equipment. I will print your response and keep it to reference when I try to make this switch again.
Thank you
Saundra
