BobC99's avatar
BobC99
Tutor
Jul 17, 2016
Ping Local IP devices
Is it possible to Ping local connected IP addresses on different VLAN/subnets connected to the LAN ports, for example (192.168.0.5), from the FVS336Gv2 Web Interface while connected remotely? This would be very helpful in trying to debug local LAN issues if for some reason a LAN device was reported to be non responsive. I know that pinging on the WAN side is possible through WAN ports 1 and 2.
  • I don't see the "Accepted Solution" button any where on this message board,, where is it??
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi BobC99,
    If I got your concern correctly, you will remotely connect to the web-GUI of the FVS336Gv2 from outside your network then you will ping a local IP address via Monitoring > Diagnostics on the web-GUI of the FVS336Gv2, am I right?  If ever I am right, I believe this is possible.
    DaneA
    NETGEAR Community Team
      • DaneA's avatar
        DaneA
        Hi BobC99,
        Just want to follow-up on this.  Were you able to remotely connect to the web-GUI of the FVS336Gv2 from outside your network then ping a local IP address via Monitoring > Diagnostics on the web-GUI of the FVS336Gv2?
        DaneA
ProSupport for Business
