caleb87
Apr 25, 2024Aspirant
port forwarding doesnt work with PR60X router and M4300-48X switch
I am unable to get the public IP to forward to an internal IP. I've setup port forwarding many times, but I can't get it working on this equipment. I'm using a PR60X router and a M4300-48X switch. ...
schumaku
Apr 26, 2024Guru - Experienced User
ShadowMario3 wrote:
Have no issues with the port forward working on both my main (10 gig WAN) internet and backup internet when I had to use failover.
One port forwarding active magically on two WAN interfaces?
Would you mind to tell us more about failover - no word of this in the user manual.
With an eye on community know-how: We're keen to know why and how you have to RDP port forwardings configured. Are these the same RDP ports forwarded from both WAN connections?
ShadowMario3 wrote:
Have you tried doing a factory reset of the router to see if that would help out? That would probably be the last thing I would do.
Suspect more a problem with ports already in use for the router own local/internal usage, like for the Web UI, when the OP does talk of http and port 80. Not the first Netgear (and other brands) router struggling over these basics. I would try some alternate port forwarding, assuming the router can deal with PAT, e.g on some random port like 80123 for example.
ShadowMario3
Apr 26, 2024Luminary
Yeah, from the last time I had a failover occur, I was able to use RDP through the second IP with no issues at all. I can do another test tonight to confirm this.
FWIW, my setup is I have a GoNetspeed (regional fiber company) with a static IP as my main WAN, connected to the WAN2 port. I have Comcast as my backup internet connected to WAN1, which, while dynamic, doesn't use CGNAT. Since OP mentioned that the port forward is working through another router, I assume that they are not behind a CGNAT.
As for how I did the port forwarding on the PR60X, I didn't need to specify which WAN ports it would apply to, I just made sure that External IP Address was set to "Any". First, you need to make a new rule under Service Management that specifies the ports.
Once they are added (or if you want to use one of the pre-defined ones), then you can go to the Port Forwarding page and they will appear in a list of rules when you add a new entry:
I have never used the predefined ones myself, so I was never able to check if port 80 had the issue like you mentioned.
As for why I have two RDP ports connected to the same internal IP, it's because that device is my Netgear RS700 router, which I have all of my computers hooked up to. I know that I am in a double NAT situation, but I don't mind this setup since I am still able to set up a VLAN through the PR60X so I have the RS700 dedicated for my main network and another router that is used for my Guest and IoT WiFi.
