CDEFrance
Dec 29, 2012Aspirant
Port Forwarding with FVS336G Dual Firewall
I have the FVS336Gv2 Dual Firewall and I am trying to set up basic port forwarding to allow access to our web server from the other side of the wall (ie through the Internet). Once I can get access to...
CDEFrance
Thank you for your prompt reply.
As I've set the Firewall to translate to port 80 the web server should not need to be looking at port 7777.
The port number declared here 7777 is not the actual number I'm using anyway.
The Firewall should be translating http://externalfixedipaddress:7777 to http://192.168.0.253:80 and the web server wouldn't know the difference.
Thanks
Thanks
