BGy
Oct 31, 2016Tutor
PPTP VPN instable
The PPTP VPN of our FVS336Gv3 is configured according to instructions in KB article. I connect to FVS336Gv3 from home, using a Windows 10 VPN Client. The Win LAN address is 192.168.0.0/24, when conne...
- Nov 17, 2016
Hi BGy,
You're welcome! :) I'm glad you have configured L2TP/IPsec successfully and it seems this works best for you.
Since you have chose L2TP/IPsec over PPTP VPN, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
BGy
Nov 06, 2016Tutor
Version is 4.3.4-2. I tried continous ping test: when RDP freeze, I no longer can ping 192.168.50.100 or any machine in the remote network.
I guess stability depends on the traffic. I left alone my machine after establishing VPN connection. After 2 hours, it was still connected but when I opened RDP it freezed after some second.
BR
FramerV
Nov 06, 2016NETGEAR Employee Retired
Hi BGy,
How many users are connecting via PPTP? Note that the FVS336Gv3 has a maximum of 25 simultaneous PPTP user sessions only.
What authentication are you using? You can probably lower it to PAP only.
You could also consider using L2TP as it has about double the throughput over PPTP VPN. It might help the connection.
PPTP has around 6.5 Mbps while L2TP has 11-13 Mbps.
