chucktdriscoll
Apr 03, 2026Follower
PR460X crash
My PR460X on firmware 2.7.0.111 (current latest available) sometimes crashes. Stack trace from the crash logs below. This appears to be a firmware/driver bug. 2026-03-13T13:34:28+00:00 router....
c3po2
Apr 03, 2026Apprentice
Are you using IPsec VPN? If so, you may try to change Fast Path Engine option to "Software Acceleration" and/or Disable IPsec VPN hardware acceleration to see if crash goes away. You can also "Enable Debug Log" for VPN to see more details about the crash. Please file a support ticket with NETGEAR and provide debug log for a solution. Thanks!
- c3po2Apr 03, 2026Apprentice
To access advanced debug options, please visit: https://ip_of_pr460x/advanced_debugging.html
