gnwjr
Nov 27, 2014Aspirant
Problems with Internet Connectivity
This will be a long-winded explanation so please bear with me... Router: NETGEAR ProSafe Gigabit 8 Port VPN Firewall FVS318G (Firmware Version: 3.1.1-18) Wireless Access Point: NETGEAR Wireless N ...
gnwjr
Nov 28, 2014Aspirant
fordem wrote: What are the ip settings on the problem laptop when ...
a) connected directly to the modem?
b) connected via Ethernet?
c) connected via WiFi?
I presume that you just wanted the IP addresses and that being the case, here you go:
a) Connected directly to the modem: 71.11.169.0
b) Connected via Ethernet: 192.168.1.6
c) Connected via WiFi: 192.168.1.20
adit wrote: Delete any saved wifi network settings and reconnect.
Not sure what you mean by this. I will say that I deleted all static assignments on the router for the laptop. Those assignments were as shown above. Then I shut everything down, turned everything back on, and the router assigned the same IP addresses the the laptop. Those listed above are the newly assigned dynamic addresses as there are no assigned addresses for the laptop.
I do appreciate your help and advice on this.
