gnwjr
Nov 27, 2014Aspirant
Problems with Internet Connectivity
This will be a long-winded explanation so please bear with me... Router: NETGEAR ProSafe Gigabit 8 Port VPN Firewall FVS318G (Firmware Version: 3.1.1-18) Wireless Access Point: NETGEAR Wireless N ...
RX
Dec 12, 2014Luminary
Borya wrote: After upgrade FVS318G to Firmware Version: 3.1.1-18 We see very strange behavior, users lost Internet access but still can connect to central office resources.
We have two FVS318G (Firmware Version: 3.1.1-18) devices, connected to different providers, but symptoms are the same.
Before upgrade to Firmware Version: 3.1.1-18 we had no such problems! :(
Hi Borya,
Have you tried doing a MAC Spoof? If yes, kindly try this because this might help: Connect your main PC directly to your modem and if you are able to go online, reconnect the modem back to the WAN port of your FVS318G then connect the main PC to a LAN port of your FVS318G and check if you are able to go online.
