CloudLostItAll
Aug 30, 2015Aspirant
Prosafe FVS114 Dynamic DNS provider page displayed as blank
Before updating the firmware from v1.1_11 I thought that I had the DDNS page available. After updating the firmware to v1.1_15 the page does not show up. It comes up blank. Is this a problem wit...
CloudLostItAll
Sep 21, 2015Aspirant
I have loaded the following Firmware Ver. onto the FVS114 router:
1.1_01
1.1_06
1.1_10
1.1_15
After each loading of the different firmware versions I reset the router to factory setting & nothing shows up on the Dynamic DNS page.
It comes up blank (color gray) with no text showing.
P.S. so something has changed in the router & I am not sure what it is at this point, since I had the page before uploading the 1.1_15 ver. of the firmware.
CloudLostitall
- SamirDSep 22, 2015Prodigy
If you have tried reverting the firmware, then I have to believe it is in the browser that you're using. Try a completely different computer with a completely different browser. Also, one that may be older may be best since the firmware is also dated. (I will usually use a linux live cd for this type of testing--easiest way since you can use the same physical machine.)
