Salata
Jul 19, 2016Follower
ProSafe FVS318G - How to disable autosensing / Auto-Uplink on WAN interface
Hello dear community, can you please advise, is it possible to disable subjected feture on WAN interface on FVS318 VPN firewalls? The reason is, one of the remote sites gets the backup iridium link ...
DaneA
Jul 19, 2016NETGEAR Employee Retired
Hi Salata,
Welcome to the community! :)
I'm afraid to inform you that it seems there is no option to disable it. However, on the web-GUI of the FVS318G, when you go to Network Configuration > WAN Settings > Advanced then on Port Speed, you can manually select the port speed. By default, AutoSense is selected on the Port Speed. Kindly check page 2-13 of the FVS318G reference manual here.
DaneA
NETGEAR Community Team
