Salata
Jul 19, 2016Follower
ProSafe FVS318G - How to disable autosensing / Auto-Uplink on WAN interface
Hello dear community, can you please advise, is it possible to disable subjected feture on WAN interface on FVS318 VPN firewalls? The reason is, one of the remote sites gets the backup iridium link ...
JohnRo
Jul 22, 2016NETGEAR Employee Retired
Hi Salata,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
