Sil68
Nov 09, 2015Aspirant
Connection drops/connection timeouts with Netgear FVS381N
Hi, Just recently I've switch ISP (to a cable provider), and in doing so my infrastructure changed accordingly. Now I've got a cable modem (technicolor TC7200U) linking my LAN to the big wide wor...
DaneA
Nov 17, 2015NETGEAR Employee Retired
Hi Sil68,
How did you deactivate NAT on the FVS318N? Did you enabled Classical Routing?
Have you tried to consult and asked assistance from your Internet Service Provider on how to set the TC7200U as a modem-only device?
DaneA
NETGEAR Community Team
Sil68
Nov 18, 2015Aspirant
Hi DaneA,
Yes, indeed, that has been the case, de-activating NAT by switching to classical routing.
I'm afraid the cable company is not very supportive with regards to device re-configuration, that's why they've limited the feature set in the admin ui.
Sil68
- DaneANov 22, 2015NETGEAR Employee Retired
Hi Sil68,
In Classical Routing, you will need to use static Public IP Addresses for each device in your LAN such as PCs.
It is sad to know that your ISP is not that cooperative about their client's concerns.
DaneA
- Sil68Nov 23, 2015Aspirant
Hi DaneA,
Indeed it is. :(
Theoretically I've got the power of 75Mbps at my fingers....
...as said, theoretically.
...not to mention all the hassle because of dropped connections and so forth
Sil68
