BGy
Oct 31, 2016Tutor
PPTP VPN instable
The PPTP VPN of our FVS336Gv3 is configured according to instructions in KB article. I connect to FVS336Gv3 from home, using a Windows 10 VPN Client. The Win LAN address is 192.168.0.0/24, when conne...
- Nov 17, 2016
Hi BGy,
You're welcome! :) I'm glad you have configured L2TP/IPsec successfully and it seems this works best for you.
Since you have chose L2TP/IPsec over PPTP VPN, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
DaneA
Nov 10, 2016NETGEAR Employee Retired
Hi BGy,
Is the Windows 10 VPN client connected wired or wireless?
Kindly try to lower down the MTU size on the FVS336Gv3 and this might help. Kindly read pages 66-67 of the FVS336Gv3 reference manual here on how to change the MTU size.
Let us know the results.
DaneA
BGy
Nov 10, 2016Tutor
Hi DaneA,
Windows 10 client connected wired.
Tested two MTU:
- 1492: PPTP VPN connection established succesfully, but I can't open Remote Desktop.
- 1400: I can't open VPN connection neither L2TP nor PPTP.
c:\>ping kb.netgear.com -f -l 1472
Pinging netgear-us.custhelp.com [129.152.38.176] with 147 bytes of data
Reply from 129.152.38.176: bytes=147 time=114ms TTL=241
Reply from 129.152.38.176: bytes=147 time=120ms TTL=241
Reply from 129.152.38.176: bytes=147 time=116ms TTL=241
Reply from 129.152.38.176: bytes=147 time=113ms TTL=241
Ping statistics for 129.152.38.176:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 113ms, Maximum = 120ms, Average = 115msThe max is 1472, trying MTU 1473 results no echo ("Packet needs to be fragmented but DF set." ).
But 1472+28=1500 which is the router default.
What MTU do you recommend?
BR
