BGy
Oct 31, 2016Tutor
PPTP VPN instable
The PPTP VPN of our FVS336Gv3 is configured according to instructions in KB article. I connect to FVS336Gv3 from home, using a Windows 10 VPN Client. The Win LAN address is 192.168.0.0/24, when conne...
- Nov 17, 2016
Hi BGy,
You're welcome! :) I'm glad you have configured L2TP/IPsec successfully and it seems this works best for you.
Since you have chose L2TP/IPsec over PPTP VPN, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
DaneA
Nov 16, 2016NETGEAR Employee Retired
Hi BGy,
I just want to follow-up on this. Any updates?
DaneA
BGy
Nov 17, 2016Tutor
Hi DaneA,
I gave up struggle with PPTP... I configured L2TP/IPsec successfully, it seems very stable and throughput is double (13 vs. 6.5MBps). But there is a decision to use IPsec with Netgear VPN Lite Client soon, in order to achieve the maximal (44Mbps) VPN bandwith. Thank you for your support.
My personal opinion and recommendation to others: It does not make sense to struggle with PPTP, forget it, use L2TP.
BR
- DaneANov 17, 2016NETGEAR Employee Retired
Hi BGy,
Cheers,
DaneA
