baloba2's avatar
baloba2
SRX5308 - DHCP client list not working after upgrade to 4.3.4-1
Hi.
After upgrading to 4.3.4-1 I cant see the dhcp client list in "lan groups"
It only shows the fixed bindings that I have made.
In release notes for that firmware:
"Fixed the issue where the LAN Groups take a long time to be displayed."
And its correct......It shows very fast but the information is missing :)
Have I done someting wrong or is it a bug in the new firmware ??
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello baloba2,
    Welcome to the community!
    I've looked at the reported issues and known limitations for version 4.3.4-1 but did not see anything related. Did you try using other browsers? I cannot say that this is a bug as of now.
    Thanks,
    • baloba2's avatar
      baloba2
      Hello and thanks.
      I dont know what just happened.
      I tested explorer 11 and edge,,,,,,on two pc.
      It didnt work
      Downloaded chrome and it worked.
      Now it works whith explorer also......Hmmm.
      Thanks for the help :)
      Do you know why all my apple products shows up as unknown ??
      When I check the logs it shows the name of the unit..
      /Jerry
      • JohnRo's avatar
        JohnRo
        Hi baloba2,
        That was weird. It might be something with the browsers, could have been cache. I'm not sure about the apple products, if their hostname is defined they should show up fine. Did this issue occured after you have updated the firmware?
        Thanks,
ProSupport for Business
