don_daniel
Nov 27, 2016Tutor
srx5308 lan wan rules with different external to internal ports
hi there i have some problems with my servers and nas in my lan to set the UPNP on the netgear firewall... so i started to use the lan wan rules that will direct to the correct servers from external...
JohnRo
Nov 28, 2016NETGEAR Employee Retired
Hello don_daniel,
I think you can use "Translate to Port number" in this scenario. You will add a service (ie. HTTPS using port 443) and use a different port number.
Thanks,
