don_daniel
Nov 27, 2016Tutor
srx5308 lan wan rules with different external to internal ports
hi there i have some problems with my servers and nas in my lan to set the UPNP on the netgear firewall... so i started to use the lan wan rules that will direct to the correct servers from external...
JohnRo
Dec 02, 2016NETGEAR Employee Retired
Hi don_daniel,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
- don_danielDec 05, 2016Tutor
my apologies for the late reply. I am on a business tryp and have no possibilities to check.. but from the content this might be the solution I was looking for..
will get back wit test results in about 10 days
