itsbatman
Aug 26, 2015Tutor
SRX5308 scheduled reboot active after disabling
By mistake I enabled a scheduled reboot on my SRX5308 every day at 00:00, but even after disabling it it still reboots.
Any help is appreciated, thanks in advance.
- DaneANETGEAR Employee Retired
Hi itsbatman,
Kindly answer the questions below:
a. What is the current firmware version of your SRX5308?
b. Have you tried to manually reboot the SRX5308 by unplugging/re-plugging its power cable and check if same problem will occur?
I look forward to your response. Welcome to the community! :smileyhappy:
DaneA
Netgear Community Team
Thnx for the reply.
1. Firmware is 4.3.3-5
2. I think I have done a manual reboot / power off, but I will do it again now just to verify and we will see what happends in 24 hours (it just had it's daily reboot 15 min ago).
I do realize that I can probably just reset it to factory defaults or reflash the firmware, but I don't want to reconfigure it (I'm assuming restoring saved settings will just restore the problem), so I'm hoping there is a better solution out there.
Thanks again in advance.Can confirm full power down didn't help. It just rebooted again, as usual 00:00 :'(
