slords's avatar
slords
SRX5308: Secondary Addresses not working with latest firmware (anything after 4.3.0-19)
I've been using the SRX5308 for years now and have never had an issue with secondary addresses.  After upgrading the firmware this last month the secondary addresses fail to work.  Everything else appears to work fine but not secondary addresses.
I've done the whole reset and factory reset both before and after upgrading the firmware and it doesn't help.
I enter the secondary addresses and firewall rules and nothing gets passed through like it should.  However, if I reboot into an older firmware (4.3.0-19) everything starts working like it should.  I've tried every firmware going back to 4.3.0-19 and that is the first one that works like it should for secondary addresses.  If I try the latest firmware (4.3.4-1) and enter everything like I think it should be and then reboot into the one that works (4.3.0-19) it just comes up.  I don't need to reset anything.  I then reboot back to the broken one and it is still broken.
I'm not sure what changed between 4.3.0 and 4.3.1+ but something broke secondary addresses at this point.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi slords,
    With regard to this, I advise you to open an online case with NETGEAR Support at anytime.  Kindly state your concern and the troubleshooting steps you did to isolate the problem.
    DaneA
    NETGEAR Community Team
    • slords's avatar
      slords
      How do I do that.  I try and open a case through My Support and it keeps running me around in circles and eventually gives me a choice of either Ask the community (pointing me here), or search the knowledge base.
      Trying to follow http://kb.netgear.com/app/answers/detail/a_id/26905/~/creating-a-support-case-through-mynetgear doesn't work.  I don't see the button to "Submit a new Online Support Ticket". I get "Contact Support" button at that point.  Clicking on that I get "Answers before I buy", "Help with my Netgear product", "Replace my defective product".  The only one that makes sense is "Help with my Netgear Product".  Clicking on that has me pick my product.  From there I get the suggested Knowledge base articles and the two choices I list in the first paragraph.
      I'd love to open an online case but I can't.
      • DaneA's avatar
        DaneA
        Hi slords,
        Kindly follow the steps below:
        1. Login to your MyNETGEAR account using your credentials.
        2. Click on "My Support".
        3. Click on "CONTACT SUPPORT".
        4. Click on "Get help on my NETGEAR product."
        5. Choose the NETGEAR product (that corresponds to the Serial Number you have already registered) that you need help with then click Next.  Otherwise, register it first.
        6. Click on the (+) plus sign that says "I cannot find an answer to my problem, I would like to contact NETGEAR support."  Then, it will show you support options.
        7. On the NETGEAR support options offered, you may either select "Open an email ticket" or "Chat with an expert" or "Call us"
        8. After you have clicked on the NETGEAR Support option you want to proceed with, you will need to fill-up the necessary fields then click Next to proceed.
        Hope this helps. :)
        DaneA
ProSupport for Business
