MWisniewski's avatar
Nov 23, 2016
[SRX5308] Warranty return - need to wipe it or leave some marks?
I am asking community, because I have all the support options disabled for now. I am replacing SRX5308 under RMA #1760362 due to sudden and frequent connection loses. If device is going to be investi...
  • DaneA's avatar
    Nov 24, 2016
    Hi MWisniewski,
    Welcome to the community! :)
    Returned units will go through general hardware testing upon return.  It is best that you remove the certificates, user accounts and keys before you send the faulty unit for replacement.
    If ever you have received the replacement unit, be sure to observe if the same problem will occur after you have set it up.  If ever its still the same problem, you may still seek assistance from NETGEAR Support in reference with the RMA #1760362 that was provided to you.
    DaneA
    NETGEAR Community Team
ProSupport for Business
