H3llGhost
Oct 08, 2011Aspirant
SRXN3205 and VDSL
Hello, we have replace our WNDR3700 with the SRXN3205, because it can't handle very much WLAN clients. But now we are facing the problem, that the router doesn't use the full speed of the VDSL. I...
jmizoguchi
Oct 08, 2011Virtuoso
you did not do your homework
Throughput
LAN-to-WAN: 60 Mbps
Connections: 20,000 concurrent sessions
VPN throughput: 20 Mbps
http://www.netgear.com/service-provider/p roducts/security/wireless-VPN-firewalls/SRXN3205.aspx
Throughput
LAN-to-WAN: 60 Mbps
