H3llGhost
Oct 08, 2011Aspirant
SRXN3205 and VDSL
Hello, we have replace our WNDR3700 with the SRXN3205, because it can't handle very much WLAN clients. But now we are facing the problem, that the router doesn't use the full speed of the VDSL. I...
jmizoguchi
Oct 08, 2011Virtuoso
it's not feature... you need CORRECT wan-lan through put spec
VDSL has NOTHING to do with router/gateway does NOT have built-in modems
if you need business class that will do over 100Mbps then
http://www.netgear.com/business/products/security/wired-VPN-firewalls/SRX5308.aspx
or prosesure UTM series (prosecure.netgear.com)
***FVS318N is newest that is wireless unit and spec at 95Mbps yet small builder spec 60Mbps at result on their site
http://www.smallnetbuilder.com/security/security-reviews/31587-new-to-the-charts-netgear-fvs318n?start=1
