Alffie
Jun 06, 2018Aspirant
Traffic shaping configurations on SRX5308
Hi, I need to set the Traffic Shaping Configuration settings to match my isp. Where do I put the shaping values for rate and burst in?
- Jun 07, 2018
Hi Alffie,
Welcome to the community! :)
There is no option to configure Traffic Shaping on the SRX5308. It might be that you are pertaining to QoS such as QoS for VoIP. Kindly check the link below as reference:
HOW TO CONFIGURE VOIP QOS ON A NETGEAR PROSAFE SRX5308
The settings to configure Traffic Shaping is seen on the Smart Managed Pro and Fully Managed Switches of NETGEAR. Kindly refer to the links below as reference:
Rate Limiting / Traffic Shaping
NETGEAR Smart Managed Pro Switches
NETGEAR Fully Managed Switches
DaneA
NETGEAR Community Team
DaneA
Jun 07, 2018NETGEAR Employee Retired
Hi Alffie,
DaneA
- DaneAJun 12, 2018NETGEAR Employee Retired
Just following up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- AlffieJun 13, 2018Aspirant
Thanks DaneA,
Looks like we will need to upgrade thankyou.
