Marksmt
Nov 07, 2016Aspirant
UTM-25 to FVS336G migration. Dialogue differences and selection of internal default NetgearVPN certs
Hi all I have almost finished migrating the config an elderly UTM-25 to a new FVS336G FWR. However, when transferring existing VPN settings I noticed that the UTM had an option to select the inter...
Marksmt
Nov 09, 2016Aspirant
Hi Dan
Many thanks for the response.
I spotted that stuff in the manual, but I wondered if I would be correct in deducing that "trusted certificate" in this context excludes Netgear internal default ones. i.e. from an implementation point of view does this imply that I need to purchase/source a trusted cert from a CA? Does this mean I can export the existing internal trusted (?) Netgear cert from the UTM and import into the FVS?
Regards
MS
Dan_Z
Nov 09, 2016NETGEAR Expert
Hi Marksmt,
The root(trusted) certificate can use to FVS,but other self cert can't,need to regenerate.
Thanks,
Dan
- JohnRoDec 14, 2016NETGEAR Employee Retired
Hi Marksmt,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
