npl102
Jan 09, 2016Initiate
UTM25 SHA2-512 Integrity not working with VPN Client Pro
UTM25 FW version 3.6.2-4 VPN Client Pro version 6.12.001 I've had some strange issues getting the VPN Client Pro to work with the UTM25 with different encryption settings. It seems that I can't...
DaneA
Jan 10, 2016NETGEAR Employee Retired
Hi npl102,
Welcome to the community! :)
Kindly answer the questions below:
a. What is the Operating System of the PC that you used? Have you tried other PC/s or laptop/s as well?
b. Does same results occur if you will have a VPN Client-to-Box setup using the UTM5?
c. Was the VPN Client-to-Box setup (using SHA2-512, etc) working before the UTM25 was upgraded to v3.6.2-4?
I look forward to your response.
DaneA
NETGEAR Community Team
npl102
Jan 12, 2016Initiate
Hello DaneA,
A. I tried 3 different machines: Windows 7 Professional 32, Windows 7 Ultimate 32 and Windows 7 Ultimate 64. All with identical results.
B. Have not tried Client-to-UTM5. UTM 5 is configured at a remote office. The Gateway-to-Gateway connection between the UTM5 and UTM25 is working fine with: AES256, SHA-256, DH16 for both the IKE and VPN policies.
C. This is a new configuration that I’m trying to get up and have only tried the latest version (v3.6.2-4) on both boxes.
As I mentioned, I’m using Mode Config on the UTM25 for the Client-to-box configuration. Any combination of settings works as long as the Integrity Algorithm is SHA-1 for the Mode Config TSL. If I change the Integrity Algorithm to SHA-256 or SHA-512, it will open the tunnel, but I can’t ping anything from the remote PC.
Below is a table showing the various combinations I’ve tried. Most of them work (I can access the network when the tunnel is opened) except for the 2 in red. In all cases the VPN Client Professional software shows the tunnel is open, I get an IP address from the pool and the DPD_R_U_THERE and DPD_R_U_THERE_ACK messages are being passed back-and-forth (shown in the console as I have dead peer detection enabled)
| IKE | |||||||
| Encryption | 3DES | AES256 | AES256 | AES256 | AES256 | AES256 | AES256 |
| Authentication | SHA-1 | SHA-1 | SHA-512 | SHA-512 | SHA-512 | SHA-512 | SHA-512 |
| Key Group | DH2 | DH2 | DH2 | DH2 | DH2 | DH16 | DH16 |
| Mode Config TSL | |||||||
| Authentication | SHA-1 | SHA-1 | SHA-1 | SHA-256 | SHA-512 | SHA-1 | SHA-1 |
| PFS | DH2 | DH2 | DH2 | DH2 | DH2 | DH2 | DH16 |
| Open Tunnel | YES | YES | YES | YES | YES | YES | YES |
| Communicate | YES | YES | YES | NO | NO | YES | YES |
- DaneAJan 13, 2016NETGEAR Employee Retired
Hi npl102,
With regard to the isolation of the problem you did, I encourage you to open an online case with NETGEAR Support then report about your concern. It is possible that VPN logs will be needed to be analyzed as well.
DaneA
