KevinCloch
Jul 24, 2015Aspirant
VPN speed: windows8.1 accepting incomming vs hardware VPN
Hi, I have a Win8.1 virual machine running on a NAS and Win8.1 is accepting incoming connections(VPN). This is located at the office where I have an ISP connection 200Mbits/s down; 15Mbits/s up. At ...
- Oct 08, 2015
I've run into similar situations with speed and one of the best things you can do is set up a site-to-site connection. This way, all the vpn overhead is in the routers. I can max out our 4Mbit upload pipe where our servers are almost 600mi away using a site-to-site configuration.
BrianL2
Jul 25, 2015NETGEAR Employee Retired
Hi KevinCloch,
Upgrading your NETGEAR home wireless router with a ProSafe VPN router will greatly improve the VPN throughput (Download/Upload). Kindly check this device datasheet for comparison (also with other models).
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
KevinCloch
Aug 02, 2015Aspirant
FYI
I bought a FVS318N Prosave router.
PPTP passtrue remains les then 5mbits/s
I configured the FVS318N to receive IPSec client connection with the VPN client software of Netgear.
I get 9.85Mbits/s.
So this is close to the max connection speeds, as my upload of my ISP connection is 10Mbits/s
Thx for the advice on upgrading my router.
Kevin
- BrianL2Aug 02, 2015NETGEAR Employee Retired
Hi KevinCloch,
Congratulations! Hope you're happy on your our newly bought NETGEAR ProSafe VPN router. If you have any questions, just create a new topic or discussion.
"Teamwork makes the DREAM WORK"
Kind regards,
BrianL
NETGEAR Community - SamirDOct 08, 2015Prodigy
- BrianL2Oct 10, 2015NETGEAR Employee Retired
Hi SamirD,
Thank you for sharing and I hope other members will see that this suggestion as a good insight in case they encounter the same. I hope you will continue to contribute in the community by asking giving out suggestions and sharing ideas.
Kind regards,BrianL
NETGEAR Community Team- SamirDOct 10, 2015Prodigy
You're welcome.
I just hope to get some good help when I run into trouble. While I've amassed quite a bit of knowledge about the netgear products I own, there is always something new to learn.
