brianstorm
May 05, 2017Aspirant
VPN Tunnel Connects but No Traffic Over LTE Connection
Hi, I'm trying to connect a windows pro 7 laptop running prosfae vpn client professional to an FVS338. The FVS338 is behind a DG834 router and I can successfully connect if I take the laptop home...
DaneA
May 07, 2017NETGEAR Employee Retired
Hi brianstorm,
Welcome to the community! :)
Kindly answer the questions below:
a. As I understand your initial post, I assume that the FVS338 behind the DG834 is located somewhere (possibly at work) and you are able to established VPN connection just fine using your laptop with your ADSL connection at home, am I correct?
b. Since you mentioned that the FVS338 is behind the DG834, is the DG834 set as a modem-only device (configured as bridge mode) making the FVS338 the main router?
c. Is the internet service provider (ISP) on your 3G/4G LTE router the same as the ISP on the where the FVS338 is deployed?
d. Is the LAN subnet on the FVS338 different from the LAN subnet on the 3G/4G LTE router? For example: the LAN subnet on the FVS338 is 192.168.1.0 and the LAN subnet on the 3G/4G LTE router is 10.10.10.0.
DaneA
NETGEAR Community Team
brianstorm
May 11, 2017Aspirant
Hi DaneA,
did you get a chance to read my responses? I'm still stuck on this and any help would be much appreciated...
Thanks in advance
