BluepenD
Nov 29, 2015Aspirant
VPN01L VPN Client Software and FVS336V2
Will the VPN01L Prosafe VPN Client (Security Policy Editor 10.8.3, build 6) work with FVS336v2 VPN Router? I use this older VPN01L client on an XP machine that I do not use often, and I do not wis...
- Dec 01, 2015
Hi BluepenD,
This shouldn't be an issue since VPN01L supports any IPSEC VPN Client router. I suggest that you try the same settings on another PC using VPNG01L (trial version) for isolation.
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Dec 01, 2015NETGEAR Employee Retired
Hi BluepenD,
Kind regards,
BrianL
