BluepenD's avatar
BluepenD
VPN01L VPN Client Software and FVS336V2
Will the VPN01L Prosafe VPN Client (Security Policy Editor 10.8.3, build 6) work with FVS336v2 VPN Router?    I use this older VPN01L client on an XP machine that I do not use often, and I do not wis...
  • BrianL2's avatar
    Dec 01, 2015
    Hi BluepenD,
    This shouldn't be an issue since VPN01L supports any IPSEC VPN Client router. I suggest that you try the same settings on another PC using VPNG01L (trial version) for isolation.
    Kind regards,
    BrianL
    NETGEAR Community Team
ProSupport for Business
