anonymous2
Nov 03, 2011Aspirant
Wireless Guest setup via FVS336G
Greetings,
I have recently upgraded our Firewall device to the FVS336G when we moved over to a T1 from DSL. Our LAN side is getting DHCP via an SBS server and the FVS336G is simply being used as the Gateway (Nat) and Firewall. Now I want to connect a DLINK DIR-655 wireless device for Guests to use to get out to the internet, isolated from our network.
On my old setup I did this one level above our firewall router, on the DSL modem, creating a seperate WAN-LAN network connection using one of our available static IPs from our ISP provider to get the DLINK onto the internet seperate from our Internal LAN.
Is this something that I can now accomplish within the FVS336G? The only thing I read that seemed in the ballpark was to perhaps to connect the Dlink via the DMZ port as it appears to be set up by design to be isolated from the main LAN. I think then I would need deal with securing a port that is designed to be more "open" security wise. The DLINK has some amount of Firewall type protections available.
Any pointers in the right/better direction would be greatly appreciated.
-Patrick
- jmizoguchiVirtuosoif you have fvs336Gv2 then use DMZ and put DLINK as AP mode . DMZ will have it's own DHCP so you do not need to use dlink as router
http://kb.netgear.com/app/answers/detail/a_id/965
if you place the port8(DMZ) then it will not associate with primary LAN until you open DMZ-LAN rules..
DMZ has it's own rules so you can limits the outbound to just http/https or whatever you decide - anonymous2AspirantJune,
Thanks for the guidance. I set it up as you suggested and after setting the DMZ-WAN outbound rules it came up just fine. I couldn't find reference to the LAN-DMZ setting, but I left them alone (nothing entered / no modifications to FVS336Gv2 defaults) and was not able to successfully probe one LAN to the other (which is the desired result in my scenerio).
-Patrick - jmizoguchiVirtuoso
http://interface.netgear-forum.com/FVX538/lan_wan_rules.htm
I don't have FVS336Gv2 on hand but most interface is same with DMZ support. Should see like fix demo
Anway, you go it working so looks like all good..
enjoy
